inspection cover for TH400 wanted
01maroonz71
Palmetto, fl
i can't find one at the local yard, and mine is missing off my truck. what do you want shipped to 34203??? THANKS!!!!!:D
are you looking for the aluminum one with the bolts or the tin one with the little bolts or screws? I have an aluminum one
oh, im not sure....will they both fit, or were there different bellhousings???? if they're the same...what do you want for it?
different housings. the aluminum ones have a larger lip on the bellhousings to have the bolts thread in. I'd take $25 shipped for it
If you look on your tranny you should have either 6 holes, 3 on each side if you need the aluminum cover, or 4 holes 2 on each side to take the tin cover.
I also have the aluminum but you already have a line on one.:D
