supernaut
Registered Member
I'm going to install ORD's weld in frame repair kit & steering box brace this weekend. I'm not a welder, so a friend is helping me with that part. A
few questions I thought of...
- When "V" grooving the cracks what kind of bit do I use? A cone shaped stone bit maybe?
- Should I drill a hole at the end of the longer cracksto make sure they stay terminated after the repair?
- When grinding the welds flush to the frame what kind of bit do I use? A sanding disc? What grit would you recommend?
- In the product reviews Steve Fox mentions buying longer grade 8 bolts to mount the steering box - I'm wondering what length(s) I should get
ahead of time so I've got a few sizes to choose from?
- Any other Gotchas you can think of ?
