TSGB
1 ton status
The first is called Idle Right. What happens is you turn off your rig, leaving your lights, winch, blower, whatever operating. When the unit detects a low voltage that is set depending on various parameters such as diesel/gas, number of engine cylinders, etc., it starts the vehicle. The truck will run until it reaches a high voltage such as 12.5- 13 volts, and then it turns off again until the battery runs low. If the vehicle is tampered with or the hood is opened, the system disables the vehicle.
http://www.havis.com/idleright.htm
The next item is called Secure Idle. You can activate the unit, remove your key from the ignition, and leave the vehicle running with no risk of theft. If the vehicle is tampered with, the unit turns off the vehicle.
http://secure-idle.com/
Here's one for diesel guys. This is called the Auto Eject. You plug your 120VAC shoreline in, for example a block heater. When the vehicle starts, the crank signal from the starter (or a manual switch, whatever you want) trips the spring in the unit, unplugging your shoreline, leaving you free to drive away without destroying your cord/household wiring.
http://www.kussmaul.com/091-55-20-120.html
We use Pop Locks relay boxes to control and power the module door and compartment locks, and interface with chassis locks. Here's their site:
http://www.poplocks.com/
Whelen cornering lamps and modules I'm afraid I can't find information for. They take a turn signal and use it to trigger a solid light that shines from your fender, illuminating the area to the side of your vehicle. Here is a picture from a truck I installed them on. The dual-light assemblies on the fender and above the rear wheel have a cornering lamp installed in the bottom.
Santa Cruz gun locks offer a number of automotive and residential fire arm mounts.
http://www.santacruzgunlocks.com/
Another product I'd like to talk about are Magnum Inverters. They take 12VDC and produce 115VAC in 1000W, 2000W, and 2800W models, and can take shoreline power and function as a battery charger. Avoid the 1000W, they fail extremely frequently, sometimes before they leave our shop. These can be ordered with a number of automatic-on functions: controlled manually, via ignition power, or another 12V positive condition.
http://www.magnumenergy.com/
