Ok, with the dmax down, the 91 is back on deck.
Hasn't been driven a ton this summer. Has developed a warm knock/stumble, and a weird creaking.
The knock. Runs pretty good until warmed up, and then still runs good for another 10-15 min.
Then under moderate throttle, it has a bad hesitation/knock. Pulled a knock sensor code, replaced knock sensor, no improvement. Although, not a delco sensor. Amazon was late, so i put in an off brand. Delco going in next week.
What could it be? Feels like the computer is cutting spark, but maybe something in the ign system? Plugs/wires/cap/rotor are low mileage.
Creaking. Frame creaks/pops when steering, and close to lock. Everything is lubed, replaced steering box, adjusted preload, everything. Frame isn't cracked, have ORD brace on, steering box is tight. Have been under the truck when someone turns the wheel, and can't pinpoint it. Do the frame crossmember rivets loosen up and creak over time? Its a disturbing noise that needs to get fixed.
Thoughts? I'm really good at throwing parts at problems, but on this one, i'd like to trouble shoot at least a little.
