beater_k20
Banned
the lockup is non adjustable, its either on, or off. check out www.73-87.com for a cheap easy way to wire it up so it works.
big83chevy4x4 said:it could be as simple as a stuck valve.
Originally posted by beater k20 but it is not the cause of the metal shavings you see in the fluid
WantedaDodge said:you mean you where spraying WD 40 into the transmission itself? I might try this, since it is the same transmission.
read the rest of the post kid. they do not produce enough to make a noticable difference in fluid color. if they do produce enough shavings to bee seen in the oil, you'll hear them, you damn sure wont be able to miss it.dirtwarrior17 said:The filter is for anything that drops down into the pan but the gears "can" produce shavings.
This message is hidden because dirtwarrior17 is on your ignore list.</SPAN>
daleearnhardt01 said:Ya know I hate to but in but Ive been reading dirtwarriors posts the past few days and Ive about had enough of his "know it all" attitude.
Boy you need to grow up and realize you dont know everything and stop acting like you do because its getting very annoying...
I have noticed that from his first post. He thinks he knows how most everything works, which in some aspect he does understand a handfull of things but in a broad range, no details.daleearnhardt01 said:Ya know I hate to but in but Ive been reading dirtwarriors posts the past few days and Ive about had enough of his "know it all" attitude.
Its the things like axles, brake boosters, etc that i don't really have a clue about but i know the 700.
not entirely true, yes other gears are soon to follow, yes it is the strongest points, but not because of any pressure booster. the "low" in the low/reverse pack is only enguaged when the shifter is in 1 (manually shifted) and reverse, there are 5 different points holding it in manual 1, as opossed to 4 on every other gear when selected manually. when the selector is in OD, there is only 3 points holding every gear, thats why D is stronger than OD (other than the fact that 3-4 clutchpack is the smallest and it has leverage against it)in addition to TJ's diagnosis, if reverse is gone, the others are nor far behind. low gear and reverse are actually "the strongest" points in the trans, as they run through a pressure booster to boost line pressure and hold the clutch packs and/or bands tighter.
