kodiakisland
Registered Member
I've found a 14 bolt from a 89 1/2 ton with a 6 lug. I'm assuming this is the semi float and most of the posts I see are about the FF. They want $150.
I was looking at replacing the gears on the 10 bolts I currently have. I figured this might be a lot cheaper as I'm sure it's got at least 4.10 gears and maybe some type of locker. Is a semi float worth the trouble? Will I have to move the spring perches or shock mounts?
