handloader90
Building!
Hello,
I've been looking at these wheels, specs and link below.
I plan on putting some 37x12.5x16.5 HMMWV tires on them.
Also, it says that they're not "Beadlock Functional"... can I still utilize a weld-on beadlock with them safely?
Wheel Diameter:16.5 in.
Wheel Width (in):9.750 in.
Wheel Material:Steel
Primary Wheel Color:White
Wheel Finish:Gloss
Manufacturers Wheel Series:U.S. Wheel 70 Series 8-Spoke Wheels
Backspacing (in):4.750 in.
Offset:-16.00mm
Wheel Construction:2-piece
Beadlock Functional:No
Beadlock Included:No
Lug Nut Seat Style:Conical seat - 60 degree
Hub Centric:No
Center Cap Included:No
Load Rating (lbs):2,200 lbs.
Valve Stems Included:No
Quantity:Sold individually.
Wheel Bolt Pattern:8 x 6 1/2 in.
http://www.summitracing.com/parts/usw-70-6980/overview/
Wheel Finish:Gloss
Offset:-16.00mm
Hub Centric:No
. I know that the weld-on beadlocks have to be fully welded. I'm still stuck on if that specific wheel in my first post is good to go on a D60/14BFF with backspacing and such and if it's able to have a beadlock welded onto it.
