Confedneck79K30
3/4 ton status
Hey all, I am in need of a bulkhead connector, engine bay side preferably with about a foot of good or decent harness for my 91 r3500 454/465 truck. Anybody gots?
Which side, inside the cab or under the hood? I have an 86 cab with the inside harness cut off at the steering column.Hey all, I am in need of a bulkhead connector, preferably with about a foot of good or decent harness for my 91 r3500 454/465 truck. Anybody gots?
Sorry, I need the underhood sideWhich side, inside the cab or under the hood? I have an 86 cab with the inside harness cut off at the steering column.
There are three separate connectors on the under hood side. Headlights, engine, and taillights. You need all three?Sorry, I need the underhood side
I need the bulkhead connector under the master cylinder that has a 10mm head bolt running through it. Snagged one today from a 77 (so the guy says) just to have it.There are three separate connectors on the under hood side. Headlights, engine, and taillights. You need all three?
On the newer ones it's different like Kenny said, it's 3 pieces that interlock and form the plug.I need the bulkhead connector under the master cylinder that has a 10mm head bolt running through it. Snagged one today from a 77 (so the guy says) just to have it.
Then yes, i need all three. Thanks for clarifying!On the newer ones it's different like Kenny said, it's 3 pieces that interlock and form the plug.
