- Joined
- Feb 1, 2017
- Posts
- 32
- Reaction score
- 51
This is partly technical, partly bench racing discussion. The topic: Repurposing e-lockers from modern vehicles.
The question- Has anyone used a Hummer H3 factory rear e-locker in a front 10 bolt axle application?
I’m building a mild adventure rig out of my 1990 Jimmy for hauling the family around in the mountains. I plan to run 35” tires and want to keep it looking mostly stock, with factory 6 lug wheels. For easy parts availability anywhere in the country my overall goal is using factory parts, specifically junk yard stuff when possible to keep the cost down (and for the pure fun of tracking down parts and building stuff on a budget). Of course it’d be easier to just order new stuff and drop it off a shop to be built, or just buy CUCV 1 tons. But that’s not really my goal at this time. I already have a Jeep on tons and 40's for hard core stuff.
The H3 rear axles are all over salvage yards for $250-400 with the e-locker and 4.56 gears (if you want to run used gears, but that’s another topic).
On paper it works- the H3 has a 10 bolt rear axle with 30 spline shafts, the same as my front axle in my 1990 Jimmy. I believe that locker would drop in to my front 10 bolt correct? Aside from wire harness routing through the diff, any other issues I might run in to? If the H3 e-locker was designed as a rear application with 33 inch tires, then it should surely hold up in the front, right?
Try to keep this thread on track, I'm not looking for other locker suggestions. I have zero interest in an ARB (I don’t want air lines or air leaks) and I’m not looking at full time lockers (power trax or detroit) right now. My goal is an e-locker for easy on/off and great street driving, and keep axle shafts alive for as long as possible. I know someone will say something about detroits are no problem on the street; I know, I have plenty of experience with them. I’ve driven Jeeps with front/rear detroits on the street and offroad for 20 years.
For the rear axle I have a six lug semi float 14 bolt. It’s loaded with 4.56’s and an eaton e-locker. I gave $100 for the 1980’s truck axle, geared and locked with 8 lug shafts. I paid another $150 for a 6 lug axle, and used the shafts and brake backing plates and to covert the 1980’s axle to 6 lug, and bolt it in to the K5. So that's the junk yard/used parts spirit I'm going for here.
And a pictures of the rig, because everyone likes pics.
