Clod_King
I don't have an electrical diagram for an 86' chev.
That being said, I wanted to know if there were wires going through the firewall that I could hack in too.
I need 12v signal from ignition.
And I have that orange wire. I tried looking at that write up on the Binder Planet forum, and he used it with a relay to go around the oil sender unit. I am keeping my oil sender unit for the time being. Do I still use that long length of orange wire? Or should I just coil it up and save it for later?
And I need to know which terminal to hook up to for the starter signal. Is it on the solenoid? Or on the starter??
I have more questions, but I forget right now.
It's a common error for beginning auto techs to set up the initial engine firing order with the #1 cylinder setup on the exhaust stroke. Usually a beginning auto tech will only make the firing order setup for the TDC on the exhaust stroke error just once!
