dave w
My wiring diagram 89 C/K shows:
Pin A - Black wire / White stripe = GROUND
Pin B - White wire / Black stripe = ECM A9 DIAG INPUT
Pin C - Brown wire = Air Divert Switch and to ECM Pin C2 Air Divert Sol Ctrl
Pin D - Brown wire / White stripe = ECM A5 Service Engine Soon (SES) Indicator and is spliced into Instrument Cluster Brown wire / yellow stripe
Pin E - Orange wire = ECM A8 DIAGNOSTIC Enable In
Pin F - Tan wire / White stripe = Trans TCC Solenoid and kickdown relay and ECM A7 TCC/Shift Indicator
Pin G - Red wire and then spliced into Red wire / White stripe going to Fuel Pump Relay
Pin H - Light Blue / Black strip = RWAL Module
For Data Logging I think all that is needed is the Pin A, Pin E and Pin B.
dave w
dave w
Thanks Dave.
But I have a few questions... (yes more)
I have two wires coming out of the ALDL hookup that are not going to anything. It seems I forgot about them.
A tan/black wire, and a greyish wire. They both went off to the fuse panel with the dash board wire loom, and my donor vehicle has been towed away already, so I cannot go exploring.
Do I need these wires?? Will I still get the data logging? I'll try and get the pin locations for those wires.... I don't think the colors are very useful.
) but since it was quiet before then got really loud, sounds like something is wrong. Did you already mention tank condition? Only thing I can think of is that it is having to work harder now, as something might be plugging the pickup? (or the pickup itself is leaking)
