Score a FREE Membership sticker when you sign up for a Premium Membership and choose the recurring plan.
Just so Avery4jc is not alone here
Discussion in 'Pre-runner | Desert Racing' started by ktmoutfront, Feb 8, 2008.
  1. ktmoutfront
    ktmoutfront Stuck going nowhere fast Premium Member GMOTM Winner
    Feb 20, 2007
    12,352
    4,303
    Would rather be on the road
    Build(s):
    3
    Update.
    A little prep for wheeling season. I don't know what it is about rebuilding shocks, but I just enjoy working on them. Even when one has puked it's guts out all over everything.
  2. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,589
    1,489
    Pinckney, MI
    Build(s):
    3
    You should take more pictures! Wiper seals went?
    sreidmx likes this.
  3. ktmoutfront
    Feb 20, 2007
    12,352
    4,303
    Build(s):
    3
    On the shock that I bent the shaft on. Seal lasted a year. But finally gave up. An O ring started leaking on a rear, so doing that one also.
  4. bent72
    bent72 Desert Solitaire Premium Member GMOTM Winner
    Dec 3, 2002
    11,464
    10,424
    colorado
    Build(s):
    So many jokes there...
    JoshHefnerX and sreidmx like this.
  5. ktmoutfront
    Feb 20, 2007
    12,352
    4,303
    Build(s):
    3
    Only for a demented mind.
    campfire and sreidmx like this.
  6. sreidmx
    sreidmx Fortify Offroad Vendor
    Oct 24, 2013
    5,848
    3,971
    Morongo Valley Ca
    Build(s):
    5
    It's therapeutic that's why you like it! It's one of my favorite pastimes..
    bent72 likes this.
  7. sponsoredbydad
    sponsoredbydad Dune Slaying Sand Junkie Premium Member GMOTM Winner
    Mar 12, 2004
    2,397
    478
    Dana Point "So Cal" "The sue me state"
    Build(s):
    Aren't we all a little demented here. At least I've always thought so. I pulled into a shell station and the attendant said I've blown a seal,I said leave my personal life out of it and fix the damn thing
    brut4s, max 02, bent72 and 1 other person like this.
  8. ktmoutfront
    Feb 20, 2007
    12,352
    4,303
    Build(s):
    3
    I rebuilt the 2 shocks. New seals and fluid throughout. Wierd thing is, the right front corner sat 2" or so too high.???????
    Figured something was hung up. Could not find anything. I did not turn the preload ring. Did not switch front to back as I did them one at a time.
    2 years ago, I had to run the preload ring down to level the truck because I assumed a coil was going bad. Never messed with it even when I changed the bent shaft. Could not figure out what was wrong.
    Finally ran the preload ring up to match the other side and everything is level. No idea why it did this.
    Also fixed the trans adapter bolts that kept coming loose. Was going to put longer bolts and capture nuts in. Not enough clearance on the back side for a nut. So lock washer and locktite will have to do.
    Also used my new, as of August, wire clamp tool on a weepy power steering line. Screw type clamps always left a flat spot in the hose. So the tube was always wet. Worked great.
    All of the bags have been organized and packed. Took pictures so I know what is in each bag.
    Ready for Moab memorial weekend.
    bmxbryant9, max 02, campfire and 3 others like this.
  9. sponsoredbydad
    Mar 12, 2004
    2,397
    478
    Build(s):
    Ready for Moab.
    Wish I could say the same about Dune Fest, my by-passes look as oily as those in the picture
    sreidmx likes this.
  10. jekquistk5
    Jan 18, 2004
    11,589
    1,489
    Pinckney, MI
    Build(s):
    3
    My coilovers are still in a box, and my links are made of PVC. :doah:
    bmxbryant9 likes this.
  11. ktmoutfront
    Feb 20, 2007
    12,352
    4,303
    Build(s):
    3
    You guys had better get on it.
  12. jekquistk5
    Jan 18, 2004
    11,589
    1,489
    Pinckney, MI
    Build(s):
    3
    Putting in 2-3 hrs a night while keeping wife and kids happy.
  13. sponsoredbydad
    Mar 12, 2004
    2,397
    478
    Build(s):
    PVC links should be fine it's only sand, and don't even worry about a hood. It's all good
  14. ktmoutfront
    Feb 20, 2007
    12,352
    4,303
    Build(s):
    3
    If you wrap them with duct tape, you can go faster.
    sreidmx, campfire and 4door99 like this.
  15. jekquistk5
    Jan 18, 2004
    11,589
    1,489
    Pinckney, MI
    Build(s):
    3
    Yah hood is the last priority.
    sreidmx, bmxbryant9 and 4door99 like this.
  16. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,865
    162
    Paducah, KY
    I thought it was zip ties?
    sreidmx likes this.
  17. ktmoutfront
    Feb 20, 2007
    12,352
    4,303
    Build(s):
    3
    Adds too much weight when completely covered for strength.
    sreidmx and AJMBLAZER like this.
  18. sreidmx
    Oct 24, 2013
    5,848
    3,971
    Morongo Valley Ca
    Build(s):
    5
    I thought wood screws were used for rigidity??
  19. ktmoutfront
    Feb 20, 2007
    12,352
    4,303
    Build(s):
    3
    After 2 runs at the local off road park, and nothing fell off, I'll be glad to be out of the cold and wind. Ready for some warmth.
    Leaving for Moab Thursday morning.
  20. ktmoutfront
    Feb 20, 2007
    12,352
    4,303
    Build(s):
    3
