I searched on this and not seeing much.
Took my M1008 to a well known alignment shop and told them it needs alignment and its pulling the right. Also, its one of the few shops that can align tires that are 37" tall. Most won't. They work on many jeeps and other 4x4's along with suspension lifts, etc.
Anyway, get it back, still pulls to the right. Alignment spec sheet looks good. Bring it back to them and they try to swap the tires, inspect all the tie rod ends, king pin bushings, made sure all tires were same psi, etc. They said there is nothing else they can do to fix this.
Anyone else run into this issue of the Dana 60 pulling left or right?
I read some Dodge and Jeep guys are installing stabilizers that have 100 or 200psi to help offset this issue.
Truck has 5" lift, crossover steering, and new 2wd steering box with ORD brace.
