If you take the injector pump out and take it to a pump shop they can increase fuel flow and pressure to create more power but with it smoke increases mileage drops and engine life shortens. There used to be a shop in Portland Or. that hopped up 6.2 pumps with good results.
As long as you stay within reason it shouldn't cause any issue with shortening engine life, and if you keep your foot out of it there is really no mileage loss.my diesel teacher suggested that the problem with 6.2/6.5's was the injection pump... he said they were built to make the engine run lean, and it would burn it up... what do y'all think about that...?
Correct me if I'm wrong, but the whole "too lean" theory is only true with a gasoline engine. Technically I do not believe "lean" or "rich" really even applies to diesel engines. The air intake is not modulated on a diesel, so it's all about the quantity of fuel you put into it. Less fuel just equals less power, more fuel equals more power...to an extent.
I agree with you on the "to lean theory" as you said the air intake is not regulated.
The basis of my original comment is that I have had three 6.2's and of the three only one actually had decent power and it smoked, and only got around 20mpg with 3.08s 700r4 and 33''s. the other 6.2's I had got between 28 and 30 mpg with hardly any smoke and same gearing w/TH400 . I have a buddy who has had a couple pumps built up,plus he ran a electric fuel pump before the stock pump he had these in a suburban on 35''s and it had alot of power but smoked like crazy, fuel mileage was in the mid to low teens and in the four years he ran this setup he went thru two motors.
Hey 6.2 Blazer, Sorry if I came across like I was being argumentative, I didn't mean it that way at all I was just trying to explain where my thoughts came from on the subject. I by no means am an expert on any of this.
I think the only difference engine wise is the J code manifold. Theres not much of a aftermarket for it. I love my cucv but its bare bones. I too got mine cuz it was cheap.
So what do the different 'code' manifolds do for you? More power, reliability, etc?
