Not to mention allows you to swap to a 241 case, which is nicer, and can be had with mechanical vss.
A 241 case can be run with either of the transmissions in question.
Do you currently have a 205 case?
As stated at the beginning, truck has a 205 in it currently that I will use no matter what
An added bonus of the 4L80E over the 400 also is its longer, helping alleviate some pain the front shaft causes that we all have seen before.
The one drawback to a Gear Vendors OD on the rear output of the transfer case will be you can only use it while in 2wd..(which may not be a big deal,since its mostly intended to reduce highway rpms..)
There was a "Ranger" gear splitter OD that went between the tranny and engine,but were only for manual transmissions as far as I know..
I think your right about the 4L80E being the "cheaper" & easier way to get OD and if you look around,you may well be able to score a good one for say,500 bucks from a salvage yard...
But that is harder than you would think, haha
