I know Its supposed to be two birds but I did three in this case.
Anyways, needed to replace my my rear drivshaft ujoint at the tcase, so I removed the drivshaft and replaced both ujoints. Then decided to go ahead and replace the yoke on the 203 because one of the tabs that holds the ujoint cap in place has been broken off. So before I installed the replacement yoke, I figured this was a good time to install my 203 partime shaft
. So in three hours I had replaced two ujoints, installed a 203 partime kit and replaced the yoke.
The partime kit was pretty easy to install, just had to pay attention to the direction of how to install the shaft and not lose any parts. I ran threw all the gears to make sure everything works. Its going to be interesting to see if I get betta gas milage.
. So in three hours I had replaced two ujoints, installed a 203 partime kit and replaced the yoke. The partime kit was pretty easy to install, just had to pay attention to the direction of how to install the shaft and not lose any parts. I ran threw all the gears to make sure everything works. Its going to be interesting to see if I get betta gas milage.
