jeremywrags
Hi All,
I am in the process of installing new body mounts along with the ORD 1" aluminium puck body lift. As you can see from the pics there is a large gap above one of the mounts (position #5) near the fuel filler. Although not torqued down yet none of the other mounts had a gap so I want to make sure that things are not to bad before I start tightening things down.
Also I know shims are required for alignment but this gap looks a little big for shims, it's probably big enough to fit another 1" puck...
Pic #1 Is position #4 on the drivers side, this shows the body resting on the mount
Pic# 2-4 shows various views of # 5 mount which is the one in question
