I haven't started my LSX nightmare swap post as of yet.
Currently the shop in vegas that did the hack work will not return my calls...txt's or emails. My problem is i have a perfectly good 350 tbi engine...700R4 there i need to have picked up so i can bring it home. Problem is 1...non communication...problem 2...if i go there again i will be going to jail.
If someone could help me get everything out of there and to a safe place where i can drive in and pick it up i will fill your gas tank to the top and give you a 100 dollars for your trouble. Muddysub is aware of this and has no way of getting the items out of said shop but can show you where the shop is.
List: 350 tbi. Complete drop...ie: its only missing the distributor and tbi unit as it was sitting on the shops floor and i brought them home. Aluminum fron mounts...starter..intake..altenator...exhaust manifolds.. hoses should still be on motor. 700R4. Radiator with factory hold downs. Engine fan (vortec late model style) with clutch fan....fan shroud... Engine belt. Factory gauge cluster. Center console inner carpet and factory floor mounts. No idea but i would assume my old exhaust which was fairly new should be there in pieces as well.
Drop me a PM if you can help out.
Thanx everyone.
DW
Thanx everyone.
DW
