But when the engineers designed it, did they want it to flex? Why are most trucks now made from box frames? If flex was so good in the frame then why did they get away from that concept?
It's not that they *wanted* it to flex, or that it's good. It's that they had to work within the design parameters, and those requirements resulted in a ladder frame chassis being the logical choice. They knew that it would flex, so it was built to deal with it. You can see evidence of that throughout the chassis. Do you really think the flex was a surprise to them? No, they new it would flex and exactly how much and where. With the exception of the steering box issue, this was pretty much taken care of in the design and material selection. And FWIW, even the newer boxed frames flex, just not as much.
And even without rock crawling mods/use, stock trucks flexed like mad when carrying a load across uneven ground. GM, Ford, Dodge, they all used the same basic design for trucks up until recently when the tendency to box increased, big rigs use the same basic design, so the bottom line is it works and it's not a bad design even for our purposes. The vast majority of people screaming that "FRAME FLEX IS EVIL! WHAT WAS GM THINKING!" can't even articulate a decent answer for why they feel that way. Mostly it comes down to "It just doesn't *look* right and I don't like it". Even those few who do have real reasons will find that there are actually more effective and easier solutions to their problems that trying to stop the flex "the right way"..
So anyway, the point is that ladder frames flex, the engineers designed it to flex without damage, and people who simply tie the cage to the frame or box part of it to "eliminate that evil flex" are breaking the "designed to deal with the flex" part of the design. This causes significant troubles for long term durability. I don't care if so-n-so ran a cage tied to the frame for however long, it's a bad idea IMO and it will lead to failure. How long it will take to fail depends on MANY things. If a person does not like the flex for whatever reason, IMO, there is only one way to address the issue, and I've mentioned it many times already. You *must* use the cage to lock down all suspension mounting points just like Beck and Stephen have done. Otherwise, the suspension is still going to flex the frame and work it against the much more rigid cage mounts resulting in a failure much like that seen around the steering box. Just like the steering box, it may be years away in surfacing, but rest assured, it IS fatiguing and weakening the frame.
Dear god, I've been sucked into one of these debates again. I've got to start ignoring these.
