I’ve heard & read a lot of good things bout Tuff Country springs, figured I could inquire to all y’all here in the 4x4 world. Your opinion’s & experience with all the different brands, before I purchased my lift kit.
I will tell you what I have on my Jimmy and you can take it for what its worth.
I do not have a traditional lift kit. I have stock springs with Skyjacker Add a leafs all the way around. Shocks are Monroe coil over load adjusting shocks all the way around. Supposed to be good for an additional 1100 additional pounds per pair. The Jimmy sits at GVW fully fueled, so 6400 lbs. I run 35x10.50 tires which actually measure at closer to 36". My rims DO NOT have the right offset so I had to use wheel spacers to get the tires to clear the rotors. I bought the same kind that is used on dualies, just not as thick. Mine are 1.5". Tires rub a little when axles are flexed out.
That being said, the Jimmy rides as soft as my wife's Honda Pilot with Bilsteins and the roads here in NorCal absolutely suck. The Jimmy sits high enough to where I can turn over underneath it without ripping my shirts. Me personally, I don't like lifting anything sky high, changes the center of gravity and makes it hard to run through orchards or the woods.
