bad larry
Morning fellas, Im new here, tryin to gather a little info for my mild build. I've got an 88 V30 I bought it last year all stock from the original ower down in Va w 37k on the clock. Drive train is TBI 454, TH400, D60 3.73 open, 14BFF 3.73 LS. I bolted in a old weezed used 3.5 superlift, added a TBI chip/B&M trans kit, and did a 3" exhaust... B4 I had a chance to put together parts I took a job down in the US Virgin Islands on St. Croix at the Oil Refinery down here and i shipped the truck. Its taken me a year and a half to find axles but the other day the Gov auctioned off some M1008's and my friend got 5 so I bought a set of axles out of one, typical 4.56 d60 open and 14bff w detroit. My truck is my DD/once a week trail rig so I'm gunna rebuild the tons and bolt um up when I'm done. With tthe truck in its current configuration I botled up a set of H1 goodyear 36x12.5x16.5's on a set of 4.5" back space wagon wheels to check the clearence, no rubbing lock to lock drove around a little, didnt flex it (im sure it would have bubbed flexed) then took um off. With a set of zero rates and with these springs or new 4"ers do you think I could swing 38's (dont want to cut, I like the vintage look) depending on rim BS? I can grind the calipers for 15's but I dont think there is any advantege in rim diamiter? I'm also considering doing H1 12 bolt beed locks with spacers and RT 2's or maybe 38x12.5x16.5 tsl sx's. Would like to do high crossover w a 2wd box and some sort of poor man's hydro assist. Any thoughts, pics of crews or advise? Alot of great info here, thanks for your time and possible help...Last pic is my unfinnished M715 back in Maine...
come to think of it he sent me on some goose chase for axles that ended with a drw 4wd chassie, mmm front hubs....
