lock cylinder removal
nocoasthardcore
Colorado
i am trying to change the lock cylinder in my 1989 k5. i have pulled the steering wheel and the lock plate and the turn signal switch. now what? thank you
there is a small screw near the upper edge of the cylinder, remove that and the cylinder comes out. /forums/images/graemlins/waytogo.gif
Put the ignition in the run position,use something thin to slip behind the lock cylinder work it back and forth and down at the same time.Should pop loose,at least it worked on my '73.Hope that helps. /forums/images/graemlins/usaflag.gif
[ QUOTE ]
[/ QUOTE ]
Yea I changed doors and had to swap the old ones out, but I think the newer ones are different as big83 said /forums/images/graemlins/dunno.gif
Thank you all for the help. i do not have my key*thus the replacement*, so no putting it into 'run'
i posted twice, i did not realize the forum went so quickly and thought there had been an error.
also. i was surprised at the difference between the autozone part and the delco. the delco part is much heavy. even the keys themselves have a more comforting heft.
How many GM keys do ya have?
Start doing the jiggle and ya might get lucky.
Or call in a locksmith.
