lochenjons
I would like to put a locker in my k5. Currently I have the govloc in the rear which works fine and I'm guessing if I did put a locker in there I'd have to get a whole new carrier, reset gears, etc. Putting a locker in the front will make turning a lot harder I know, but I assume thats only with the hubs locked right? How hard is it to put a locker in a d44? I hear good things about the lincoln locker and the lock right, do they make ones for a d44? Any other suggestions?
You need to pull the axle shafts, so you can drop out the carrier, so you can pull the ring gear, so you can slide the cross pin out, so you can remove the spider gears. From there it's all putting it back together.
