Longfield Teflon Spindle Bushings
pomai
Oahu, Hawaii
I know the Teflon spindle bushings replace the needle bearing, small seal and thrust washer.
But the Teflon bushing will not slide thru the dana 60 stub shaft dust shield and seat with the inner surface of the stub like the oem thrust washer does.
The lip of the bushing is to big to fit thru the dust shield and seat with the stub. Should I some how take some material off the lip of the bushing so it does slide thru the shield and seat with the surface of the stub?P1030805.JPG
