looking for rear driveshaft (stock)
al525i
Registered Member
columbia, sc
hi everyone,
i just finished my th350/203 to sm465/205 swap:D but my rear driveshaft is nowhere near fitting. what i need is the stock rear driveshaft for a 465/205 combo. i don't mind if the u-joints are trashed as they will be replaced before installation anyway. i would also like the straps that hold the u-joints to the t-case as mine are trashed.
p.s.
i'm in south carolina. thanks,
al525i
you can email me at mekanikmanATgmail.com
or just pm me.
It would help if you stated what you need the SM465/NP205 shaft to fit ?? :dunno: Stock from what ??
K-5 ,K10, short bed ,long bed ,crewcab ??
ahhh. good point. (new to the 4wd world kinda)
it is a 1978 k-5 with the stock axles (12 bolt)
and the transmission is newer with a hydraulic clutch setup but the 10-spline (i think) output between the transmission and transfer case. (i know it's not the 31 spline)
thats about all i know. i'm pretty sure the stock shaft from a manual k5 will work fine in the rear because the front was a bolt in deal.
thanks,
al525i
