personaltrainer
okay I'm a newb here but I'll do the best I can b/c I'm loosing a fair amount of sleep here. $$ is an issue and I want to fix this thing as cheapy as possible, so guessing in the right direction is important.
which seal is it? - my mechanic calls it the "rear output seal" it leaks where the driveshaft plugs into the t-case. It leaked befor the problem, I had the seal replaced, and it continued to leak.
I just thought of ANOTHER clue. One day when it was about 10 degrees outside I got in the truck, started it, warmed it up, put in drive and it did not move, gave it a little gas - still did not move. I got out and looked under all of the tires and nothing was there, so i got back in, put in drive and gave it a little more gas - "BANG". The it drove like usual. It was a pretty big noise that scared the **** out of me! Befor this incident the trucvk never had this noise - it was in the weeks after this that the noise started.
Thanks for everyone's help - I appreciate your time on this thing!
