LS Swap 5.3 Exhaust Question
jfkelley
Registered Member
Oklahoma City
Im close to completing the 5.3 / 4L60e LS swap on my GM 76 K10 four-wheel-drive… Im using the stock truck exhaust manifolds and they fit between the frame rails but very tight ..Someone told me to use 2010-2015 Camaro manifolds ..Can someone confirm this ? Thanks in Advance
I have no hands on with this, but I have read that they will work, as do trailblazerSS manifolds.
I used stock GM 5.3/6.0 truck manifolds when I had the 5.3 in mine. I was using dirty dingo slider mounts with the engine in the stock location. Tightest spot was pass side near the outlet flange. Still cleared with a good amount of room.
I have Dirty Dingo Mounts as well In stock position ..My passenger side clears nicely but my drivers side fits but is very tight ..Idk if the Exhaust guy will be able to get a flange on it ..
