I've swapped an ly6 into my 86 k5 and am not sure how to route the large gauge wire. Currently I have it coming off the alternator, down around the head to the starter. However, it is tight against the head and will eventually wear through if the heat from the block and exhaust don't melt it first. Is it supposed to go directly to the battery with a fuse or something or do I need a longer wire? It is the original wire so I would think it shouldn't be that tight to the block.
...it makes replacing the fusible links a real pain..
