I've been getting the codes for lean fuel for both banks. Usually throws the light after 60-100 miles. Using the torque app it seems, when highway driving, when I'm on the gas my ltft is good. When I let off the ltft goes up to 25 at times. I've checked the fuel pressure under different driving conditions and it is good at the rail. I also pulled all the injectors and they have good clean spray patterns. The MAF is new and clean, i cleaned the throttle body, what else would cause this? Another possibly related symptom is that sometimes when hit the gas from a stop, if i am light on the pedal, it will stall. Is this a tuning issue?
