CK5 Network
Become a member of the largest online community for Chevy K5 Blazer, Suburban and C/K series truck owners!
M1008 Cucv Ls Swap
Converting my M1008 from 6.2 Diesel to LS power
Cucv_M1008
Cthulhu Forever
Premium Member
Carver, Oregon
Please tell us the details.
My 6.2 was toast so I decided to put a big block in it but i wanted decent fuel mileage so I changed my mind and went with a 5.3 with a 4l80 and a Np241 t case. I installed a ord cross memeber, new an lines for fuel and transmission lines. I had a local guy build me a harness and it included e fans provisions.
I went with a 87 and up tbi gas tank with baffles. New radiator, speed engineering headers and some gauges. I plan on cleaning up the interior with a seat recover, new dash and acc rubber floormat. I also got all new gaskets for the cab and doors and windows. I have other stuff I still need to do.
Cucv_M1008
Cthulhu Forever
Premium Member
Carver, Oregon
A while back i was installing my speedo gear and cable with the vss pulse emitter for my PCM. I used the wrong bolt on the speedo gear housing and it broke and i had to disassemble the tail shaft housing to get it out. So i got a new correct bolt and i can re assemble it with the right bolts and install my vss pulse emmitter for the pcm, should i replace the bearing in the housing?
Cucv_M1008
Cthulhu Forever
Premium Member
Carver, Oregon
If you are that far in to it, it couldn’t hurt to replace the bearing.
Replace the bearing and the tail shaft housing seal then reassembled, then my Crank trigger sensor went out and the truck would not start. Replaced that and the truck started. Hopefully this week, the fuel pump (the current pump is only pushing 45 psi, I need 60 to run). if all that falls in line and the truck runs as it should ill start on a few small things the swap needs: VSS pulse emitter on the transfer case, torque converter lockup switch, GM knock sensors, and shift solenoid on the 4l80 then onto brakes and interior and maybe driveable by October or sooner. I do need to install my Efans and wire them up also but that can wait till it's driveable.
Cucv_M1008
Cthulhu Forever
Premium Member
Carver, Oregon
Changed the fuel pump and had no affect still 40 to 50 psi of fuel and engine surges and stalls, further reading told me that the aem pump only flows 40 psi, ls engines need 60, so i need a new pump. Pulled the intake to put in gm knock sensors and oil guage fitting.
Cheavyk10
Desert Sand
Premium Member
Washington
I've been waiting on this Holley fuel pump for like 5 months now. They keep pushing the availability date back. Drop in the stock saddle tank.
