Manual swap with ECM
Tunerpro (what I was using to view that data) would probably say what the values are, but I'm not somewhere I can check.
^You're thinking too much.
Who are you refering this to? And what makes you qualified to make such a statement without publishing your facts as to what he his over-thinking?
Your post has added nothing to this discussion. :D
What has yours added???
Martin
samething as stated...91 4x4 burb/R2500??..4l80e went out...swapped in a 84 sm465....it had a 208 behind it & it bolted right up to the 91 np241...i gathered the trans wires up and made a bundle up out of the way, no adverse effects in last 3 yrs...w/the r & v designations....r is 4x....&.v = 2wd....correct?
I beg to differ. My post caused dyeager to dig up a map of both PROMs. We now have a definitive answer to what was previously speculation. I'd say that added plenty to the discussion. :D
No.
R = C = 2wd
V = K = 4wd
Martin
