I am not a manual transmission guy. I can drive them no problem but have never worked on one. Here's where we are at:
I have a 2000 model Dodge 2500 2WD with the 5.9 Cummins and a 5 speed. my wife drives this truck a lot more than I. she says it is easier to handle than the dually and she doesn't want to drive the 4X4 because it is what it is. back in April of 2018 the clutch quit working and I ordered a LUK clutch master and slave assembly from Rock Auto and put them in and everything was good. about 18 months later it started acting up again. I didn't think the assembly had went bad but a good friend that works on these all the time said it was more than likely the hydraulics again. so I ordered another and just put it on today. no change, does the same thing.
here are the symptoms: you can start in neutral but push the clutch in and it will not go into gear unless you force it. you can put it in gear and start it and sometimes it will take off even with the clutch pushed in and sometimes it won't. before I put the new one on I took the assembly off the clutch. (edit: bellhousing) I had my wife push down on the clutch slowly and I could hold the rod in place with my hand which led me to believe the hydraulics went bad. I haven't tried with the new one yet.
any suggestions?
any suggestions?
