broncoman6524
I followed a parts calatog, what I remember from when it was apart, and just what looked right.
I ended up having a big springs pulling the fork rearwards, (pushing throw-out bearing onto pressureplate) and a second between the fork and pushrod.
This seems to work fine, I looked at my friends truck and his is set up where the fork is pulled forward ( throw-outbearing off plate) and the spring between the rod and fork.
Which is the correct way? Pictures would be sweet too...
I ended up having a big springs pulling the fork rearwards, (pushing throw-out bearing onto pressureplate) and a second between the fork and pushrod. This seems to work fine, I looked at my friends truck and his is set up where the fork is pulled forward ( throw-outbearing off plate) and the spring between the rod and fork.
