newyorkin
1 ton status
I have a pair of early 90's 350's from wrecked Police Caprice's (not LT1's) I hoarded a few years ago, and I think they had over 100k on them, but I can't remember. I planned to do a swap into my K5, but then sold the K5 and just kinda let them sit.
I need to swap one into my '85 K20 now. Since the '85 is carb'd and the '91 is TBI, I'm doing a conversion at the same time. The 85's heads are the problem, so I can't just move the old top end to the newer motor.
I have a harness and ecm from an '89 K5, I may go with a GM sender/pump or just do an external and leave the tank stock.
Since I'm going to open the motor and check the bores, change the bearings, etc, I was thinking I might as well beef it up a little. I haven't even taken off a valve cover in probably 8 years (except on my minivan, but that doesn't count), so I can't remember half of what I should know.
I've never done a cam upgrade, so I never paid attention to the numbers...
I figured I'd do a cam on this motor, but I'm really not sure if I'm going to need to change the prom. Will I? Can I get a mild cam that will give me some more power without having to change the prom?
I think it's a roller motor already, so I'm not going to mess with the lifters or rockers. I'd like to leave the heads as-is, but does anyone know if heads from an '87 TPI Z28 350 will make a positive power difference? I'd think not, but I got an offer of a pair really cheap. I haven't looked at my casting numbers, but I don't see why they be different heads...
Any other suggestions for a little more power? I need to keep this as low budget as possible.
