Wyomingboy
I have a fully modified TBI unit for sale. It is bored to 46.5mm. This came off my 90 Blazer
I had it bored to 46.5mm in Ca., it has the 1/4" pod gasket to lift the injectors, it has a pair of matched 80#/hour injectors, and it has a vacuum fuel pressure regulator, that varies fuel pressure from @ 11psi at idle to @ 15+psi at WOT.
It comes with a 4bbl manifold -- TBI adapter plate.
I only ran this combo for 1 year, the TPS and IAC sensors were new when I built this. Then I decided to go to an aftermarket FI unit for more user adjustability.
$200 + shipping expenses takes it all. I also have a custom burnt chip if you are interested ???
If your not a member, You can contact me at: [email protected].
