dbreid
All,
I have a 1984 K30 with a factory BigBlock. My motor mounts needed/need to be replaced (already did the trans mount, etc) so I started researching.
See this thread for background:
http://coloradok5.com/forums/showthread.php?t=237781
Anyway, the Cliffs notes is that I got Kert to build me some RAD Bigblock in K30 frame mounts. And I bought the ORD Crossmember. So I have:
And:
To install.
OK, so in looking at the whole setup, it seems like I need to lift the motor (wood on oilpan, etc) and then use that for clearance to get the motor mounts off the block and replace them. Fair enough.
There is a post here talking about that as well:
http://coloradok5.com/forums/showthread.php?t=219944&highlight=engine+crossmember
However, it looks like I need to air chisel or essentially cut out the stock crossmember to get it out.
So:
Do I first cut out the crossmember and THEN do the mounts? Or do the mounts, and then do the crossmember?
I am not really in the mood for pulling the motor, so I'd prefer an "under the truck" method.
Thanks for any advice!
-Dan
And:
To install.
So:
-Dan
