mud boggin 9-13-09
YZEATER
TARENTUM, PA
It sounds like you've got more motor than your using, can you gear down some to get more rpm? I'm sure you've been through all this before, just a (probably offcourse) observation on my part. But...congrats anyway.
i'm open for suggestions and ideas. not sure what you mean though?
in the b class run, i shifted to second and took off. a class i shifted a bit too soon and it bogged a little and i had a little slower time then b class.
i always run low range 203, 1st gear in the th400. in d class i run 33x 12.50 boggers. in the other classes i switch to q78x16 tsl's, 34" tall.
my truck setup is in my sig. the 85 3/4 ton. autmatic with a manual valve body, it shifts when i tell it to and stays in thet gear. msd ignition with the rev limter set at 6k, i think, it has plug in clips for the limiter.
the pit is 200ft long.
classes are determined by tire size.
e - 4 and 6 cylinder up to 33"
d - 33" and down
c - up to 36.5"
b - 37" and up
a - cut and paddle tires, and nitrous.
