Just went through this entire thread, did you ever find a solution to the VDO sensor for the water temp?
I can't remember, but you used the stock 90 burb oil pressure sensor drilled and tapped into the oil cooler block off plate above the oil filter right?
What did you end up doing about the volt gauge?
