So im not 100% satisfied with the way this thing is wired. For one, its wired for an F-body computer which doesn't play nice with a truck tune. Mostly the problem there is the way the oxygen sensors are wired is much different. Also im just not satisfied with a few other things with the way i wired it into the truck. Probably it would last forever but i know i took a couple short cuts that i have lingering in my mind. So im going to totally rewire it. Im going to get a new truck side harness off a 90 burb and start from scratch there. and im going to dissect my existing LS harness and rewire it the correct way for a truck.
Im undecided if im going to keep the ECM under the dash or under the hood. Im thinking of going under the hood. I know its not as aesthetically pleasing but i just feel like its a better spot for the way the under dash is setup on this truck. There really isnt room for it. The way i had it mounted meant i had to remove the vent in the passenger footwell. By doing that i eliminated the recirculate option on the A/C. And i would really like to have that back.
Now, when i do all this, i plan on being very meticulous about documenting what im removing and splicing into so that at least the 90 guys will have what im hoping will amount to a step by step how to. I have learned a fair bit since i did my wiring on this initially and plan to put that to use to make it more of a factory wiring job as opposed to a factory wiring job with a LS harness spliced in. If that makes any sense.
I'll get started on it this winter. I have a little bit to still put together from the paint job and then i need to put the interior together still. So probably November? December? Something like that. All i know is that I will feel alot better and alot more at ease about the wiring after i redo it all.
