87 K5 350 TBI w/headers....New block, new heads, new radiator, new thermostat, new clutch fan, new water pump, timing adjusted, new sensors....WTF, it still overheats....it doesn't peg the temp gauge, but it rides just to the left of the red. With all the new goodies, the water should flow very good. There's no blockages, and it's full of fluid. So again, I ask, WTF....is it possible it's a bad or wrong waterpump?
I just tried something that I hadn't done yet...when I turn the heater on full blast, it brings it down a notch...but not to 210 or close to it. When I turn the heater off, it goes back to the redline.
If your problem goes away, test the T-stat in a pot on the stove with a meat thermometer in the water. Mine did the same thing until I swapped it out. No problems since.
