Did you try cutting the heads off the retainers that hold the shoes to the backing plates??--on a few stubborn drums I had to not only cut those "nails" off,but the wheel cylinder retainer clip too--once I took the clip and metal line off the wheel cylinder,everything fell apart fairly easy...make sure the E-brake cable has enough slack too...
Well here's one for you I just got a 14 ff from a buddy of a buddy and the drum would not come off I tried everthing, come to find out the drum and the brake shoes fused them self together, I had to cut the e brake cable bolts off the backing plate as well as the two spring retainer shafts and the large bolt that the shoe's ride against at the top then the drum slide right off, bad news the shoe still wont come loose of the drum after beating the snot out of them with a 4lb hammer, Owell time for a disc brake conversion.
ok i found a metal blade in one of my old circular saws and got thru most of the backing plate. i was aiming at sliceing at that bigbolt off and i ended up wacking it the rest of the way with a chizzle.
