TheBeast_88K5
Banned
I was thinking, instead of investing money in a bunch of~ flash~ >like 20 + cans of spray paint, and a bunch of stickers… Ill put the money into the suspention, where it counts
hahaha
have u seen "the beast's" build thread? Olive drab and a hundred other spray cans
but at least he's backing it up with trail damage
the shocks in the rear all look add on. Normally the bottom shock mount is at the bottom of the axle. The new 14b will set you up but this means your shocks will be too short for the new axle.....unless you put a mount on top of the axle. I recommend going up to the frame like original.![]()
Trail damadge????? My whole truk is trail damaged
just givin/taken a lil chit btw ,the stock shock towers in the rear have been removed ,dont see them.havent really looked.im working out the twisted mess from the front to the rear.someone posted that pic and ,,here we areoh yeah! Its going to take some time to get things right. A long, long timeif you go 14bff, you should do a shackle flip. Just sayin'.
If they're 38" TSL's, then that'll be yer problem.
TSL's kill balljoints.
I ran 35" BFG A/T's on that axle, and it NEVER wobbled.
Check to make sure the exposed thread is the same on each of the TRE's,
on the Tie Rod....
Sounds stupid, but mine was off, and made it wobble.
i just jacked it up and moved tires left to right,,,,i think you might be right. Seems >looseUpdate,,,Already +fixed+ the DW with a cheap stabilizer,and changed out the 203 with a 205, thanks to a little/lot of help from iceman,just gotta get the right crossmembers,and get the shafts dialed,cut the tranny channel.
Oh and sorry man, I pmed you Chris's address by mistake.Hehe.... Progress!
Oh and sorry man, I pmed you Chris's address by mistake.![]()
I cant wait to get my junk on the road!
