1987cut
Registered Member
Hey guys, ive been having problems out of my factory horns and decided to fix it. First i had to remove the aftermarket horn swith and wiring from the PO. Then hooked up everything and realized the relay was bad. I go to install this relay and the horn constantly blows. I pulled the contact out of the column thinking it was stuck but it still blows as long as the relay is plugged up. Im wondering if the wire in the column is grounded somehow? Any help would be appreciated. Thanks
