My new truck...
Ive got a 14bolt ff with the right gears that will be going under it.
Got the rear diff swapped out for the 14b ff...
Got the adapter off the trans and transfer case, who ever rebuilt the trans sure did love to use orange permatex....
Need to pull the slip yoke off the 208 to see if the output shaft is messed up, driveshafts as shoved all the way in and had hammer it all the off.
If your 208 got messed up and the adapter is broken I can set you up with a 205 with adapter.:D
