bp71k5
3/4 ton status
Being somewhat inexperienced with big trucks and rough roads, I learned a few interesting things about how my truck works and doesn't work as well as I hoped. I thought it might be fun to describe those things for anyone else planning a trip in future years to learn from me.
1. My front E-locker does not like to disengage without rocking back and forth several times. This sucks when you make it up part of a tight obstacle and can't turn the wheel because the tires are locked and makes steering out of some obstacles impossible. I'm not sure how to address this and so I'm not sure I can recommend the e-locker because of it. On the other side of the spectrum, the rear ARB worked perfectly once I shifted the transfer case into gear.
2. My power steering pump whined at me constantly even though it's fairly new. I don't know if a better pump would be appropriate for me, or if it's just the nature of steering tiny 35" tires without hydroassist?
3. Hi-speed freeway driving really causes a lot of heat on drivetrain. I had lube leaking out of breather tubes on both transfer cases, the transmission, and the rear diff whenever it got hot. This was messy and dangerous as Kurt mentioned. I've got to find some way to keep those cooler at freeway speeds. Does anyone make lube coolers for any of those things?
4. After about 6 hours of driving out on gold bar rim, my gas tank was about 1/4 full and I started hearing a pretty loud high-pitched whine. That's weird I thought, the fuel pump isn't very old and should be fine. I thought maybe it was another truck having an issue until I couldn't resist getting out and locating it. I discovered the whine was coming from my gas cap! I cracked it open very lightly and a huge gush of fuel vapor came rushing out. Yikes! The lack of fuel combined with a hot exhaust pipe near the pump must have not been letting it cool down enough. Evidentally the vent was also clogged. On the advice of James, I wedged a small stick under the cap gasket and continued on, seeing the weird vapor trail of fumes behind me until we got back to town. Things turned out ok, but the fuel lines need more heat protection along with a more reliable venting system.
5. Seatbelts. I've got the stock two point belts and they hold you down ok, but don't prevent you from getting shoved side to side on hours of lumpy trails. I was constantly looking forward to finding a rock ledge to climb up because I was so tires of the mild-rocky roads between them. Better seats and belts are in order obviously.
6. My rear bumper took a good hit on the golden crack and collapsed a portion of my rear fender. It was expected since my bumper was more decorative than functional. I saw almost everyone using their bumper as a skid at least once which proves to me they are useful for more than just parking lot protection from shopping carts. A more rigidly attached bumper would protect the sheetmetal a little better and provide better recovery points should I need them.
7. My gas pedel is too twitchy. Just a slight bump on the truck would cause my foot to press on the gas and cause even more roughness. I'm going to try and play with the lever lengths on the throttle body to make it less sensitive to slight movements.
Those are the highlights, most everything else worked just fine and we make it back just fine.
