I have what appears to be an extra wire running next to my temp sensor on my 74 Blazer (350). I can't figure out what it is for. I think the temp gauge works but it's hard to tell because the K5 has a 160F thermostat (based on previous owner) along with a flex fan. It doesn't get much above cold on the gauge when running since its below freezing outside and I can't drive the K5 yet, only idle but the gauge does move a little.
The wire has switched power and shows 12 volts. No power when key is off.
Green wire goes to temp sensor. This wire which is yellow or tan (can't tell) runs up behind the distributor and into the main wiring harness.
I want to replace the thermostat and coolant mixture but before I do, I want to make sure everything is working and hooked up properly. Any ideas on what the unhooked wire is for?
This is the least of my problems with this thing.
