twojoints444
Registered Member
I was dooin a lil hunting in my 83 k20 last nite and needed some 4 wheel action. As i was climbing i noticed a HORIBLE clunking noice every few seconds?? It did it in bolth 4 hi and low and sounded like it was coming from the front end?? has anyone elts ever came accross this or have any insite as to what it might b???
I seems to only CLUNK when climbing runs fine on flat ground
Since the shaft has been moded, I would put it in four low or high, lock the hubs and grab the driveshaft with both hands and see if you have any play at the CV. If everything is tight, could be the chain in the t- case... But with a recent axle swap, did you take the cover off the front axle and check the gears. If they were set up wrong or are different ratios it could very well be the teeth on the ring gear shearing off. My 14 bolt started like that with a little clunk and pop here and there. Had to keep wheeling and when I got on it hard, every tooth on the ring gear sheared off. Wasn't pretty at all. Just throwing some ideas out there. If everything looks good I'd deffinately pull the cover just to make sure. Better safe than sorry. Wish I would have....Instead I'm setting up gears next weekend. Keep us posted.... Oh and be sure to turn the truck off before you put it in gear and crawl under it........................ Not saying you won't but you would be surprised at some of the people I've met that would try it everytime....
