The Pumpkinator
Think I can get just a few more miles out of it?
My truck was in need of some new meats, especially up here in snow country, and I had some new KM2s in mind. Plains Tire offered me the best deal for the tires with their bitchin' Freedom Plan, this also included the quotes on a front end alignment and new upper and lower ball joints for the passenger's front.
The solution to this problem took a weird turn from what was suspected to be wiped out ball joints causing the passenger's tire to lean outwards, if the truck was parked on a level surface with the wheels pointing straight forward you can just make out the angle of the rim in relation to the axle and see it was pushed out at the top. What was figured a whole day of work at the shop turned into three days.
The ball joints on the passenger's side were tight as can be, the wheel bearings were seated properly and the tie rod was not bent. However the driver's side ball joints were destroyed. At first this didn't make any sense; how could the loose knuckle on the drivers side make the caster look off on the passenger's side with the passenger's side being rock solid?
The front end specialist stated that his computer data base compiled of 13 different large auto vendors had no solution whatsoever to adjust the camber on one of the most commonly found axles, even though his lasers shown it was off, I called bull
on this, and told him that there was an eccentric sleeve that could adjust the top ball joint in or out like the Fords. I needed to find proof so I dug around here on CK5 for some info and found two aftermarket solutions along with the vendor name that sells them; an eccentric preload sleeve for the top ball joint, and a shim that was sandwiched between the knuckle and the spindle...turns out that replacing the ball joints on the driver's side and adjusting the toe fixed the problem
Here is the shop data:
Front Left
Actual Before Range
Camber: 1.0 1.0 0.8 2.3
Caster : 7.9 7.9 7.0 9.0
Toe :0.02 -0.54 -0.08 0.08
Front Right
Camber: 0.5 0.4 0.4 2.3
Caster : 8.0 8.0 7.0 9.0
Toe :0.03 0.68 -0.08 0.08
Front End
Actual Before Range
cross camber: 0.05 0.7 -1.0 1.0
cross caster : -0.1 -0.1 -1.0 1.0
total toe :0.05 0.15 -0.16 0.16
After adjustments, everything checks out
. So for those caught in the situation I was in, the solution is new ball joints on the driver's side with some toe adjustments. Also while its ripped apart it wouldn't hurt to make sure the wheel bearings are packed with grease and seated properly, and the hubs cleaned out.
Front Left
Actual Before Range
Front Right
Front End
Actual Before Range
.I'm no front end specialist, don't get me wrong. I had the shop print me out the angle measurements, the data print looks nearly identical to that of your first pic, I would have just scanned and uploaded it but I don't have a scanner. Far as I know the only way to adjust the caster on a solid front axle would be to shim the leafs on the perches to make the yoke coming out of the diff pointing down or up...either that or figure out how to rotate the pressed on axle Cs (good luck), but being such a short coupled vehicle it makes sense to have the Cs tilted back as far as they are.
