Bought these July of 2017 thru Summit https://www.summitracing.com/parts/FSS-75300 Went to a bigger radiator and these didn't cover enough of the core.
They're wired up with a Leash Electronics dual 70 amp relay board. https://www.leashelectronics.com/Dual-70-Amp-Relay-Board-D70RB.htm All you need to do is add a ground wire to the battery/chassis, battery lead, switched power to the relays, and thermal switches to ground the relays and turn the fans on.
I would like $80 + shipping. I could also probably meet somewhere within 50 miles of Evans, CO.
