need a fuel sending unit electrical connector
76zimmer
Flyin Rat
Staff member
Moderator
Kzoo, Mi
what the heck kind of a connector does the fuel sending unit take for the power side...it looks like a straight pin, with no threads or anything to retain the connector onto it?
Any ideas?
yep its a funny gm thing.
i have peen a bullet conector opened up and stuffed down on the pin before.
I tried the bullet connector, didn't work too good for me. I was going to solder a wire to the brass, copper, or whatever pin. Please post up if you find something, so I can get one too. :deal:
I think its the same connector as the factory brake proportioning block. the one for the brake light in the dash. Looks the same?
I'll check that out Rick....I got a prop valve end I won't be using!
It's a goofy looking thing that just pushes onto the pin, the wire comes out the side of it.
Zimmer, If you don't find something let me know. I have many a harness around.
If you need one I can cut mine off the blazer since I'm using a fuel cell, mine is just dangling now
You can buy them at a parts store now--they have all kinds of repair ends for harnesses now ...I've used ones off starter soleoids off older jeeps,they had a terminal just like the one on GM sending units on the bottom of the solenoid for the neutral safety switch wire..
